주요 콘텐츠로 건너뛰기
Casio fx-9750GII Screen Replacement
필요한 것
  1. Casio fx-9750GII Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Casio fx-9750GII Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Turn off the calculator and flip it over so the backside is facing up.
    • Slide the battery door off and remove all of the batteries.
  2. Casio fx-9750GII Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use a screwdriver to remove the screws from the back of the calculator.
  3. Casio fx-9750GII Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the screw from the battery slot.
  4. Casio fx-9750GII Screen Replacement: 4 단계, 이미지 2개 중 1개 Casio fx-9750GII Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the back case from the calculator.
    • Be careful of the spring that shows in the second picture. The spring is the convertor of the battery.
  5. Casio fx-9750GII Screen Replacement: 5 단계, 이미지 2개 중 1개 Casio fx-9750GII Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the screws from the motherboard.
  6. Casio fx-9750GII Screen Replacement: 6 단계, 이미지 2개 중 1개 Casio fx-9750GII Screen Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Separate the screen cable from the motherboard using tweezers.
    • Remove the calculator screen.
    • Replace the screen.
  7. Casio fx-9750GII Screen Replacement: 7 단계, 이미지 2개 중 1개 Casio fx-9750GII Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Replace the board and back cover of the calculator, then install the batteries to test if the new screen works well.
결론
작성자
4다른 기여자 명과 함께
YORK-CHEN-F21SEG[2]
회원 가입일: 09/19/21
145 평판
안내서 1개를 작성함
York University, Team E-2, Melo-Thaiss Fall 2021 York University, Team E-2, Melo-Thaiss Fall 2021 회원
YORK-MELO-THAISS-F21SEG2
1 회원
안내서 3개를 작성함
2가이드 댓글
thanks for the short description and pics. my screen cable appears to be soldered directly. I would help if you said more than "separate the screen cable from the motherboard" Perhaps add another pic or two of just that description? Are you breaking the wires? are you soldering on the new replacement board? are you taking off just the screen from that main 'calculator' electronics board?
Happy Zahn - 답글
Where to get the new replacement screen?
Ahmed Farhat - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 28
지난 30일: 132
전체 시간: 4,011
