주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Caterpillar B15 LCD Replacement
필요한 것
  1. Caterpillar B15 LCD Replacement, Caterpillar B15 Teardown: 1 단계, 이미지 1개 중 1개
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
    댓글 쓰기
  2. Caterpillar B15 LCD Replacement: 2 단계, 이미지 2개 중 1개 Caterpillar B15 LCD Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
    댓글 쓰기
  3. Caterpillar B15 LCD Replacement: 3 단계, 이미지 2개 중 1개 Caterpillar B15 LCD Replacement: 3 단계, 이미지 2개 중 2개
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
    댓글 쓰기
  4. Caterpillar B15 LCD Replacement: 4 단계, 이미지 2개 중 1개 Caterpillar B15 LCD Replacement: 4 단계, 이미지 2개 중 2개
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
    댓글 쓰기
  5. Caterpillar B15 LCD Replacement: 5 단계, 이미지 1개 중 1개
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
    댓글 쓰기
  6. Caterpillar B15 LCD Replacement: 6 단계, 이미지 1개 중 1개
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
    댓글 쓰기
  7. Caterpillar B15 LCD Replacement: 7 단계, 이미지 1개 중 1개
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
    댓글 쓰기
  8. Caterpillar B15 LCD Replacement: 8 단계, 이미지 1개 중 1개
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
    댓글 쓰기
  9. Caterpillar B15 LCD Replacement: 9 단계, 이미지 1개 중 1개
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
    댓글 쓰기
  10. Caterpillar B15 LCD Replacement: 10 단계, 이미지 1개 중 1개
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
    댓글 쓰기
  11. Caterpillar B15 LCD Replacement: 11 단계, 이미지 1개 중 1개
    • Congratulations. You have successfully disassembled the Caterpillar B15.
    댓글 쓰기
  12. Caterpillar B15 LCD Replacement, LCD: 12 단계, 이미지 1개 중 1개
    • With the device completely disassembled, the LCD can easily be accessed. It is pictured here, in which it adheres to the front of the motherboard.
    댓글 쓰기
  13. Caterpillar B15 LCD Replacement: 13 단계, 이미지 1개 중 1개
    • The LCD is held to the board by an adhesive, and will peel away with either a spudger or by hand. Disconnect any ribbon cables if applicable.
    댓글 쓰기
  14. Caterpillar B15 LCD Replacement: 14 단계, 이미지 1개 중 1개
    • Installing the new LCD is the reverse of removing the old one. The 2mm 3M adhesive tape listed in the guide is recommended for fixing the new display to the board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Geoffrey Mosdell
회원 가입일: 10/06/14
1,119 평판
안내서 5개를 작성함
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014 회원
USFT-BROWN-F14S4G7
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 27
전체 시간: 7,552
