주요 콘텐츠로 건너뛰기
Ceiling Dome Light Fixture Replacement
필요한 것
  1. Ceiling Dome Light Fixture Replacement, Light Bulbs & Rewiring: 1 단계, 이미지 2개 중 1개 Ceiling Dome Light Fixture Replacement, Light Bulbs & Rewiring: 1 단계, 이미지 2개 중 2개
    • Turn the light off.
    • Leaving the power on could be dangerous.
  2. Ceiling Dome Light Fixture Replacement: 2 단계, 이미지 2개 중 1개 Ceiling Dome Light Fixture Replacement: 2 단계, 이미지 2개 중 2개
    • Twist the locking nut left to take it off.
    • You do not need any tools for this step.
    • The light cover is held together by the locking nut. Hold the light cover while twisting the locking nut, so that it will not drop to the ground and break.
  3. Ceiling Dome Light Fixture Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the light cover down from the ceiling.
  4. Ceiling Dome Light Fixture Replacement: 4 단계, 이미지 1개 중 1개
    • Twist the light bulb out of it's socket.
  5. Ceiling Dome Light Fixture Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the heat cover, also known as foil, out of the way.
  6. Ceiling Dome Light Fixture Replacement: 6 단계, 이미지 2개 중 1개 Ceiling Dome Light Fixture Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the screws halfway.
    • Twist the base of the light fixture to take it off.
  7. Ceiling Dome Light Fixture Replacement: 7 단계, 이미지 1개 중 1개
    • There are three different colored wires. Black, white and copper. The black is the power wire, white is neutral and cooper is the ground wire.
    • Remove the black wire first, since it is the power. Then the white and copper wire.
  8. Ceiling Dome Light Fixture Replacement: 8 단계, 이미지 1개 중 1개
    • Once you have twisted the base of the light fixture, the base will come down.
    • It does not matter which colored wire you reassemble first.
    • Twist each wire from the base of the light fixture to the wire in the ceiling.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kier'n Harris
회원 가입일: 07/02/18
277 평판
안내서 1개를 작성함
2가이드 댓글
Very helpful & easy to follow. Thanks!
drgf48 - 답글
Awesome, now can I put a ceiling fan up their with bigger fasteners or do I need the whole setup? Thanks
galardopt - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 47
전체 시간: 21,194
