주요 콘텐츠로 건너뛰기
Ceiling Fan Pull Chain Switch Replacement
필요한 것
  1. Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: 1 단계, 이미지 2개 중 1개 Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: 1 단계, 이미지 2개 중 2개
    • Caution: Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan.
    • Remove the white cover by unscrewing the nut on the bottom from where the chain is hanging.
  2. Ceiling Fan Pull Chain Switch Replacement: 2 단계, 이미지 3개 중 1개 Ceiling Fan Pull Chain Switch Replacement: 2 단계, 이미지 3개 중 2개 Ceiling Fan Pull Chain Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Caution: Let the bulbs cool off before you remove them.
    • Remove the bulbs from their sockets.
  3. Ceiling Fan Pull Chain Switch Replacement: 3 단계, 이미지 2개 중 1개 Ceiling Fan Pull Chain Switch Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screws around the base.
    • Remove the fan housing.
  4. Ceiling Fan Pull Chain Switch Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the switch out of the fan housing, leaving the wires attached.
  5. Ceiling Fan Pull Chain Switch Replacement: 5 단계, 이미지 3개 중 1개 Ceiling Fan Pull Chain Switch Replacement: 5 단계, 이미지 3개 중 2개 Ceiling Fan Pull Chain Switch Replacement: 5 단계, 이미지 3개 중 3개
    • Cut the colored wires from the switch using a pair of wire cutters.
    • On some switch models, the wires can be detached by pulling.
  6. Ceiling Fan Pull Chain Switch Replacement: 6 단계, 이미지 3개 중 1개 Ceiling Fan Pull Chain Switch Replacement: 6 단계, 이미지 3개 중 2개 Ceiling Fan Pull Chain Switch Replacement: 6 단계, 이미지 3개 중 3개
    • Note the wire colors and the terminal they attach to on the old switch.
    • 1 - Red
    • 2 - Purple
    • 3 - Yellow
    • L - Black
  7. Ceiling Fan Pull Chain Switch Replacement: 7 단계, 이미지 1개 중 1개
    • Attach the colored wires to the new switch's respective terminals.
  8. Ceiling Fan Pull Chain Switch Replacement: 8 단계, 이미지 2개 중 1개 Ceiling Fan Pull Chain Switch Replacement: 8 단계, 이미지 2개 중 2개
    • Put back the switch in the hole in the fan housing from the inside.
    • Tighten up the screws on the outside.
  9. Ceiling Fan Pull Chain Switch Replacement: 9 단계, 이미지 3개 중 1개 Ceiling Fan Pull Chain Switch Replacement: 9 단계, 이미지 3개 중 2개 Ceiling Fan Pull Chain Switch Replacement: 9 단계, 이미지 3개 중 3개
    • Put back the white cover and then tighten up the nut at the bottom of the cover from where the chain is hanging.
  10. Ceiling Fan Pull Chain Switch Replacement: 10 단계, 이미지 2개 중 1개 Ceiling Fan Pull Chain Switch Replacement: 10 단계, 이미지 2개 중 2개
    • Turn the power back on and test the switch to find if it is working or not.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Berkeli Alashov
회원 가입일: 02/25/21
244 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 50
지난 30일: 177
전체 시간: 16,041
