주요 콘텐츠로 건너뛰기
Ceiva LF2003 Display Replacement
필요한 것
  1. Ceiva LF2003 Display Replacement, Exterior Frame and Matting: 1 단계, 이미지 1/1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Display Replacement: 2 단계, 이미지 1/1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Display Replacement: 3 단계, 이미지 1/1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Display Replacement: 4 단계, 이미지 1/1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Display Replacement, Internal Plastic Screen Frame: 5 단계, 이미지 1/1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Display Replacement: 6 단계, 이미지 1/2 Ceiva LF2003 Display Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  7. Ceiva LF2003 Display Replacement, Display: 7 단계, 이미지 1/3 Ceiva LF2003 Display Replacement, Display: 7 단계, 이미지 2/3 Ceiva LF2003 Display Replacement, Display: 7 단계, 이미지 3/3
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  8. Ceiva LF2003 Display Replacement: 8 단계, 이미지 1/1
  9. Ceiva LF2003 Display Replacement: 9 단계, 이미지 1/2 Ceiva LF2003 Display Replacement: 9 단계, 이미지 2/2
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  10. Ceiva LF2003 Display Replacement: 10 단계, 이미지 1/3 Ceiva LF2003 Display Replacement: 10 단계, 이미지 2/3 Ceiva LF2003 Display Replacement: 10 단계, 이미지 3/3
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  11. Ceiva LF2003 Display Replacement: 11 단계, 이미지 1/1
    • Remove the display assembly from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Casey Glasgow
회원 가입일: 01/26/14
510 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 회원
CPSU-MANESS-W14S9G25
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 134
