주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Replacing the frame on the Ceiva LF2003 is very easy. No tools are required, and it only takes a few seconds.
  1. Lay the device on its back, and rotate so the base is facing away from you.
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Lift up the frame with your fingers and push down the rest of the device with your thumbs.
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Remove the frame and matte from the device.
    • Remove the frame and matte from the device.
결론
Casey Glasgow
회원 가입일: 2014년 01월 26일
510 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 회원
CPSU-MANESS-W14S9G25
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 45
