메인 콘텐츠로 스킵하기
소개
Replacing the internal frame on this device is very simple and requires minimal disassembly.
부품
지정된 부품이 없습니다.
  1. Lay the device on its back, and rotate so the base is facing away from you.
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Lift up the frame with your fingers and push down the rest of the device with your thumbs.
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  5. Remove the frame and matte from the device.
    • Remove the frame and matte from the device.
  6. Remove the four 7mm Torx T6 screws.
    • Remove the four 7mm Torx T6 screws.
  7. Using the plastic opening tool or your fingers, lift up the frame from any edge. Remove the frame from the device.
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Casey Glasgow
회원 가입일: 2014년 01월 26일
510 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 회원
CPSU-MANESS-W14S9G25
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 59
