이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the main circuit board of the device. This requires detaching all other components, including those that are soldered to the board.
필요한 것
Lay the device on its back, and rotate so the base is facing away from you.
Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
