주요 콘텐츠로 건너뛰기
Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement
필요한 것
  1. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement, Skin Cover: 1 단계, 이미지 1/2 Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement, Skin Cover: 1 단계, 이미지 2/2
    • Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
  2. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement: 2 단계, 이미지 1/2 Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement: 2 단계, 이미지 2/2
    • Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
  3. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement: 3 단계, 이미지 1/1
    • Repeat steps 1 and 2 for the other side.
  4. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement, Eyepiece Knob: 4 단계, 이미지 1/1
    • Twist the eyepiece knob counter-clockwise until it starts coming off.
  5. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement: 5 단계, 이미지 1/1
    • Repeat Step 1 for the other side if necessary.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryce Colangelo
회원 가입일: 02/15/17
525 평판
안내서 5개 작성하였습니다
USF Tampa, Team S6-G6, Lacy Spring 2017 USF Tampa, Team S6-G6, Lacy Spring 2017 회원
USFT-LACY-S17S6G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 605
