주요 콘텐츠로 건너뛰기
Celestron Nature DX Anchor Arm Replacement
필요한 것
  1. Celestron Nature DX Anchor Arm Replacement, Skin Cover: 1 단계, 이미지 1/2 Celestron Nature DX Anchor Arm Replacement, Skin Cover: 1 단계, 이미지 2/2
    • Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
  2. Celestron Nature DX Anchor Arm Replacement: 2 단계, 이미지 1/2 Celestron Nature DX Anchor Arm Replacement: 2 단계, 이미지 2/2
    • Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
  3. Celestron Nature DX Anchor Arm Replacement: 3 단계, 이미지 1/1
    • Repeat steps 1 and 2 for the other side.
  4. Celestron Nature DX Anchor Arm Replacement, Focus Knob: 4 단계, 이미지 1/1
    • Remove the top cover of the focus knob as shown. Simply twisting and pulling the cover will slide it off.
  5. Celestron Nature DX Anchor Arm Replacement: 5 단계, 이미지 1/1
    • Use a magnetic pickup tool or magnetic screwdriver head to remove the guard. The guard should come right off without much resistance.
  6. Celestron Nature DX Anchor Arm Replacement: 6 단계, 이미지 1/1
    • Unscrew the focus knob. It should come off without much resistance or pressure.
    • Parts revealed will be heavily lubricated. Consider wearing gloves.
  7. Celestron Nature DX Anchor Arm Replacement, Control Arm: 7 단계, 이미지 1/2 Celestron Nature DX Anchor Arm Replacement, Control Arm: 7 단계, 이미지 2/2
    • Locate the panels in front of the binoculars between the middle axle and the viewing lens and simply pry them off with your fingers
  8. Celestron Nature DX Anchor Arm Replacement: 8 단계, 이미지 1/2 Celestron Nature DX Anchor Arm Replacement: 8 단계, 이미지 2/2
    • Using a flathead screwdriver, unscrew the highlighted screwhead for the control arm.
    • With your fingers, grab the screw head and pull it out completely once it's unscrewed and replace it with the new control arm if needed.
  9. Celestron Nature DX Anchor Arm Replacement, Anchor Arm: 9 단계, 이미지 1/2 Celestron Nature DX Anchor Arm Replacement, Anchor Arm: 9 단계, 이미지 2/2
    • Identify the panel on the side you wish replace the anchor arm on, as marked on the photo.
    • Cut the panel open with a knife. Cut the adhesive substance around the panel with the knife and then using said knife, you should be able to lift it off.
  10. Celestron Nature DX Anchor Arm Replacement: 10 단계, 이미지 1/2 Celestron Nature DX Anchor Arm Replacement: 10 단계, 이미지 2/2
    • Identify the anchor arm. It is circled in red.
    • Using the spudger, lift the anchor arm. It should come off without much resistance.
    • Insert the new anchor arm into the now open slot.
결론
Bryce Colangelo
회원 가입일: 02/15/17
525 평판
안내서 5개 작성하였습니다
USF Tampa, Team S6-G6, Lacy Spring 2017 USF Tampa, Team S6-G6, Lacy Spring 2017 회원
USFT-LACY-S17S6G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 317
