주요 콘텐츠로 건너뛰기
Celestron Nature DX Focus Knob Replacement
필요한 것
  1. Celestron Nature DX Focus Knob Replacement, Skin Cover: 1 단계, 이미지 1/2 Celestron Nature DX Focus Knob Replacement, Skin Cover: 1 단계, 이미지 2/2
    • Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
  2. Celestron Nature DX Focus Knob Replacement: 2 단계, 이미지 1/2 Celestron Nature DX Focus Knob Replacement: 2 단계, 이미지 2/2
    • Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
  3. Celestron Nature DX Focus Knob Replacement: 3 단계, 이미지 1/1
    • Repeat steps 1 and 2 for the other side.
  4. Celestron Nature DX Focus Knob Replacement, Focus Knob: 4 단계, 이미지 1/1
    • Remove the top cover of the focus knob as shown. Simply twisting and pulling the cover will slide it off.
  5. Celestron Nature DX Focus Knob Replacement: 5 단계, 이미지 1/1
    • Use a magnetic pickup tool or magnetic screwdriver head to remove the guard. The guard should come right off without much resistance.
  6. Celestron Nature DX Focus Knob Replacement: 6 단계, 이미지 1/1
    • Unscrew the focus knob. It should come off without much resistance or pressure.
    • Parts revealed will be heavily lubricated. Consider wearing gloves.
결론
Bryce Colangelo
회원 가입일: 02/15/17
525 평판
안내서 5개 작성하였습니다
USF Tampa, Team S6-G6, Lacy Spring 2017 USF Tampa, Team S6-G6, Lacy Spring 2017 회원
USFT-LACY-S17S6G6
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Hello.
I have the same model with a little bit to hard working focus knob.
Is it possible to adjust it in order to make it working smoothly?
Tkanks.
Zenon Zuza - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 808
