소개
Ce tutoriel montrera comment enlever les anciennes bougies d'allumage, vérifier et préparer les nouvelles bougies et enfin les installer.
필요한 것
Retirez délicatement le fil de la bougie. Ne tirez pas sur le fil, serrez le capuchon de la bougie et tirez-le avec le fil.
Inspectez toujours vos nouvelles bougies avant de les installer. Vérifiez l'écart sur vos bougies d'allumage de remplacement avec une jauge d'épaisseur. Il devrait être réglé sur 0,040 pouces (1,016 mm).
Installez la nouvelle bougie dans sa cavité à la main et serrez toujours à la main jusqu'à ce qu'elle entre en résistance.
À l'aide d'une clé dynamométrique, serrer la bougie aux bonnes spécifications appropriées.
Questions.1 with a stage 1,2 or 3 would you agree a wider gap? 2nd question which is simular to first.i do run my motor a little rich.rather rich than lean.my question is with modification on a harley davidson sportster.what do ou recommend.so many choices from om to iridium to platinum.then the gap and also are you a believer in cutting the eledtrode approx half off for max combustion.how much would you recommend cutting and back to og question.the gap.is a larger gap.capable of power increase.since ive tried both i swear i feel a power increase.but is it anticipated or other varibles???you opinion is valued.
Réinstallez votre fil d'allumeur en le poussant fermement sur la nouvelle bougie.
I have a Harley Davidson Xr1200x Sportster which I just got. Changed the oil also tranny & filter as I couldn't find last date of service coang of oil. So yesterday I checked the spark plugs they were clean. But the mechanic cleaned them & said the needed gap them as one was too narrow. Mind you I had no issues at all. Gapped them at 0.40 now I'm not getting the same smooth sound or feel as if it's miss firing. I have iridium spark plugs okn my bike should I change them to NGK or get another set of iridium spark plugs.please advise..
A spark plug Gap is to be checked with a wire feeler gauge, not a flat feeler gauge….
Which wires go to which plug
Assurez-vous de répéter la procédure ci-dessus pour le cylindre restant.
다른 20명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 8개
Couldn't have made it any simpler
-awesome
- appreciated
Thank you so much for your posting. I'm 2k miles from my daughter who is teaching herself how to maintain her own bike. You site is immensely helpful and appreciated as much.
Says between 11 and 18 pounds in manuel
Is there a firing order like on a car I'm just trying to make sure I have the rite plug with the rite plug wire
I really appreciate your site…thank you.
lori milne - 답글
Can anyone tell me if a 1999 sporster has a data link connector port . my bike would not start the coil was bad replaced it now no spark at all can anyone help
