소개
The purpose of this guide is to help grill owners patch rusty and corroded drip pans on Charbroil grills with permanently riveted drip pans. Rather than discarding the grill and spending hundreds of dollars for a new one, this procedure will allow the grill owner to extend the usable life of his or her grill.
필요한 것
Make an initial assessment of the extent of the corrosion to the drip pan.
Use a wire brush to remove the most corroded metal.
Use the tin snips to remove the least corroded metal.
Upon completion, this repair will extend the usable life of your grill and reduce waste deposited into landfills.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Thank you so much for posting this. Question: what type of sheet metal? Aluminum or Steel?
What kind of material? Aluminum?
