주요 콘텐츠로 건너뛰기
Charge 3 Battery Replacement
필요한 것
  1. Charge 3 Battery Replacement, Battery: 1 단계, 이미지 1/3 Charge 3 Battery Replacement, Battery: 1 단계, 이미지 2/3 Charge 3 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • It is recommended to let the battery discharge before starting. It's a precaution to prevent the battery from lighting on fire if punctured.
    • Remove both T2 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
    • Watch out for the spring on in the band release
  2. Charge 3 Battery Replacement: 2 단계, 이미지 1/3 Charge 3 Battery Replacement: 2 단계, 이미지 2/3 Charge 3 Battery Replacement: 2 단계, 이미지 3/3
    • Heat the glass screen with a blowdryer to soften the adhesives
    • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. Charge 3 Battery Replacement: 3 단계, 이미지 1/1
    • This is how close those cables get to the edge underneath the Fitbit wording so be careful
  4. Charge 3 Battery Replacement: 4 단계, 이미지 1/3 Charge 3 Battery Replacement: 4 단계, 이미지 2/3 Charge 3 Battery Replacement: 4 단계, 이미지 3/3
    • Lift the display then battery up gently
    • The battery is attached with a little bit of adhesive so lift it gently
    • Remove battery connector
  5. Charge 3 Battery Replacement: 5 단계, 이미지 1/2 Charge 3 Battery Replacement: 5 단계, 이미지 2/2
    • Connect new battery connector
    • Peel the plastic layer off the adhesive backing
    • Put the battery back in place
  6. Charge 3 Battery Replacement: 6 단계, 이미지 1/1
    • Add a thin layer of E-6000 glue around the casing
    • Make sure to cover the entire surface that makes contact with the screen to keep the device waterproof
  7. Charge 3 Battery Replacement: 7 단계, 이미지 1/2 Charge 3 Battery Replacement: 7 단계, 이미지 2/2
    • Flip down the screen and remove any extra glue that squeezes out
    • Take a rubber band and wrap it around the device, this will ensure the display stays in place until the glue cures
    • With the rubber bands on go to step 1 and reverse the steps to reinstall the band release
    • The glue will take between 24 and 72 hours to fully cure
    • When the glue is fully cured remove the rubber bands
    • After all is done you will need to calibrate the battery to do this charge it to 100% then leave it charging for an extra 2 hours use the device until it dies of low power and finally charge it to 100% and it should be good to go
    • And walla you now have a repaired Fitbit Charge 3
결론
Thanks to ShellingRook27's Original Dissasembly I Was Able to Make this Guide And Bring a new life to my old device.
Simon Pepin
회원 가입일: 03/18/23
404 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 45
30일 전: 137
전체 시간: 644
