주요 콘텐츠로 건너뛰기
Charge 3 Touch Screen Assembly Replacement
필요한 것
  1. Charge 3 Touch Screen Assembly Replacement, Touch Screen Assembly: 1 단계, 이미지 3개 중 1개 Charge 3 Touch Screen Assembly Replacement, Touch Screen Assembly: 1 단계, 이미지 3개 중 2개 Charge 3 Touch Screen Assembly Replacement, Touch Screen Assembly: 1 단계, 이미지 3개 중 3개
    • It is recommended to let the battery discharge before starting. It's a precaution to prevent the battery from catching fire if punctured.
    • Remove both T2 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
    • Do this on both sides
  2. Charge 3 Touch Screen Assembly Replacement: 2 단계, 이미지 3개 중 1개 Charge 3 Touch Screen Assembly Replacement: 2 단계, 이미지 3개 중 2개 Charge 3 Touch Screen Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • I've performed this on a few Fitbits where the adhesive was worn out enough that with a light amount of prying the touch screen assembly lifts right up
    • A hairdryer on high should work you may have to use it for longer
    • Heat the glass screen with heat gun to soften the adhesives
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. Charge 3 Touch Screen Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • This is how close those cables get to the edge underneath the Fitbit letters so be careful
  4. Charge 3 Touch Screen Assembly Replacement: 4 단계, 이미지 3개 중 1개 Charge 3 Touch Screen Assembly Replacement: 4 단계, 이미지 3개 중 2개 Charge 3 Touch Screen Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the display then battery up gently
    • The battery is attached with a little bit of adhesive so lift gently
    • Remove battery connector
  5. Charge 3 Touch Screen Assembly Replacement: 5 단계, 이미지 2개 중 1개 Charge 3 Touch Screen Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Remove two P2 screws
    • Remove T2 screw
    • Liftoff metal shield
    • I found flipping the device and letting the shield fall out was easier
  6. Charge 3 Touch Screen Assembly Replacement: 6 단계, 이미지 3개 중 1개 Charge 3 Touch Screen Assembly Replacement: 6 단계, 이미지 3개 중 2개 Charge 3 Touch Screen Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Liftoff both display connectors
    • Remove Display Assembly
    • Connect The new screen (basically step 6 in reverse)
    • This step can be a bit fiddly to get right
    • Then perform the step 5 in reverse to put the metal shield back in
  7. Charge 3 Touch Screen Assembly Replacement: 8 단계, 이미지 2개 중 1개 Charge 3 Touch Screen Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Reconnect battery connector
    • if the battery wasn't dead before repair it should turn on now
    • Put the battery back in place
    • When I was replacing the screen I also replaced the battery that's why the battery changed.
  8. Charge 3 Touch Screen Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Add a thin layer of E-6000 glue around the casing
    • Make sure to cover the entire surface that makes contact with the screen to keep the device waterproof
  9. Charge 3 Touch Screen Assembly Replacement: 10 단계, 이미지 2개 중 1개 Charge 3 Touch Screen Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Flip down the screen and remove any extra glue that squeezes out
    • Take a rubber band and wrap it around the device, this will ensure the display stays in place until the glue cures
    • With the rubber bands on go to step 1 and reverse the steps to reinstall the band release
    • The glue will take between 24 and 72 hours to fully cure
    • When the glue is fully cured remove the rubber bands
    • And voila you now have a repaired Fitbit Charge 3
결론
Thanks to ShellingRook27's Original Dissasembly I Was Able to Make this Guide And Bring a new life to my old device.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Supper Simon
회원 가입일: 03/18/23
464 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 24
전체 시간: 799
