필요한 것
Turn ignition two clicks to the ON position
Insert a bent paperclip into the SCC connector. (See video for where the SCC connector is located)
Touch both of the exposed pins to short the connection. Continue to short the connection for more than 5 seconds.
Any codes will display on the Odometer/Trip display, or "NO" if there are no stored codes
Remove paperclip and wait 10 seconds
Turn ignition OFF and remove key
거의 끝나갑니다!
결승점
I pulled code 3 long pause and 9 fast blink D what might be the problem 39
QuintonIsaaks - 답글
