주요 콘텐츠로 건너뛰기
Chef's Choice M115 Sharpening Stones Replacement
필요한 것
  1. Chef's Choice M115 Sharpening Stones Replacement, Case: 1 단계, 이미지 1/2 Chef's Choice M115 Sharpening Stones Replacement, Case: 1 단계, 이미지 2/2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Sharpening Stones Replacement: 2 단계, 이미지 1/1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Sharpening Stones Replacement: 3 단계, 이미지 1/1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Sharpening Stones Replacement: 4 단계, 이미지 1/1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Sharpening Stones Replacement, Sharpening Stones: 5 단계, 이미지 1/2 Chef's Choice M115 Sharpening Stones Replacement, Sharpening Stones: 5 단계, 이미지 2/2
    • With the outer case removed, firmly grasp the motor-axle attachment and remove it from the base. It should come right off of the assembly.
  6. Chef's Choice M115 Sharpening Stones Replacement: 6 단계, 이미지 1/2 Chef's Choice M115 Sharpening Stones Replacement: 6 단계, 이미지 2/2
    • Use a screwdriver to push the linkage pins out of the rod.
    • Use pliers to pull the pins the rest of the way out.
    • Remove all the linkage pins necessary to slide desired sharpening stone off the end of the shaft.
  7. Chef's Choice M115 Sharpening Stones Replacement: 7 단계, 이미지 1/3 Chef's Choice M115 Sharpening Stones Replacement: 7 단계, 이미지 2/3 Chef's Choice M115 Sharpening Stones Replacement: 7 단계, 이미지 3/3
    • On the rotating apparatus, holding the sharpening stones in place, are two C-clamps that grip the axle.
    • Remove the C-clamps by applying pressure to both sides of the "C" and pushing the clamp over and off of the axle.
    • Pull the bearing off the shaft. It is in between the two C-clamps.
    • These clamps are very small; use caution to avoid dropping them on the ground or losing them.
  8. Chef's Choice M115 Sharpening Stones Replacement: 8 단계, 이미지 1/1
    • Pull sharpening stones off the end of the shaft.
    • Be sure to remember the order and placement of each individual stone so you can reassemble them in the same order.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Zachary Nagel
회원 가입일: 09/17/15
116 평판
안내서 1개 작성함
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G3
5 회원들
안내서 12개 작성하였습니다
댓글 4개
where does one get the replacement stones. im not seeing they in my amazon/google searches. also cant seem to see them on manufacturers website section for parts.
john molloy - 답글
I have the same question.
August Coombs -
same question, where do I order replacement stones ?? I have the chef’s choice Sportsman from cabelas, thanks in advance .. you can send any info to my e-mail thebobster@ns.sympatico.ca any info wiuld be greatly appreciated..
Bobby Aucoin - 답글
Same question. Where to Purchase sharpen stones. Would like to have them before I disassembled the unit. I have had my sharpener for eight years and use it quite often as my wife likes sharp knives.
Please does anybody have any information to purchase the sharpening stones
Rich - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 99
전체 시간: 5,712
