주요 콘텐츠로 건너뛰기
Chef’s Counter Rice Cooker RC-3 Disassembly
필요한 것
  1. Chef’s Counter Rice Cooker RC-3 Disassembly, Chef’s Counter Rice Cooker RC-3: 1 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly, Chef’s Counter Rice Cooker RC-3: 1 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly, Chef’s Counter Rice Cooker RC-3: 1 단계, 이미지 3개 중 3개
    • Unplug the rice cooker.
    • Remove the bowl and lid from the device and place the device upside down on a flat surface.
  2. Chef’s Counter Rice Cooker RC-3 Disassembly: 2 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 2 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 2 단계, 이미지 3개 중 3개
    • Remove the two 13 mm screws from the bottom using a Phillips #1 screwdriver.
    • Remove the base plate.
  3. Chef’s Counter Rice Cooker RC-3 Disassembly: 3 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 3 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 3 단계, 이미지 3개 중 3개
    • Remove the three 10 mm gold screws holding the wires in place using a Phillips #1 screwdriver.
  4. Chef’s Counter Rice Cooker RC-3 Disassembly: 4 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 4 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 4 단계, 이미지 3개 중 3개
    • Remove the single 10 mm screw from the metal plate using a Phillips #1 screwdriver.
    • Remove the metal plate.
  5. Chef’s Counter Rice Cooker RC-3 Disassembly: 5 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 5 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 5 단계, 이미지 3개 중 3개
    • Remove the three perimeter screws holding the heating plate in place using a Phillips #1 screwdriver.
    • One screw has a length of 14 mm and two screws are 10 mm.
  6. Chef’s Counter Rice Cooker RC-3 Disassembly: 6 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 6 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 6 단계, 이미지 3개 중 3개
    • Use pliers to pinch the metal V in the center.
    • Slide out the silver heating component and black support ring.
  7. Chef’s Counter Rice Cooker RC-3 Disassembly: 7 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 7 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 7 단계, 이미지 3개 중 3개
    • Use the pliers to pinch the three metal flaps flat and remove the spring.
  8. Chef’s Counter Rice Cooker RC-3 Disassembly: 8 단계, 이미지 2개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 8 단계, 이미지 2개 중 2개
    • Remove the metal hook that is over the thick white wire cover.
  9. Chef’s Counter Rice Cooker RC-3 Disassembly: 9 단계, 이미지 2개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 9 단계, 이미지 2개 중 2개
    • Remove the thick white wire cover uncovering the thermal cutoff fuse.
  10. Chef’s Counter Rice Cooker RC-3 Disassembly: 10 단계, 이미지 2개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 10 단계, 이미지 2개 중 2개
    • Flip over the rice cooker so it is right side up.
  11. Chef’s Counter Rice Cooker RC-3 Disassembly: 11 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 11 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 11 단계, 이미지 3개 중 3개
    • Remove the single 10 mm screw from the outer control panel using a Phillips #1 screwdriver.
    • Remove the plastic outer control panel.
  12. Chef’s Counter Rice Cooker RC-3 Disassembly: 12 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 12 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 12 단계, 이미지 3개 중 3개
    • Remove the single 10 mm screw using a Phillips #1 screwdriver to reveal the LED lights.
  13. Chef’s Counter Rice Cooker RC-3 Disassembly: 13 단계, 이미지 3개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 13 단계, 이미지 3개 중 2개 Chef’s Counter Rice Cooker RC-3 Disassembly: 13 단계, 이미지 3개 중 3개
    • Remove the single 27 mm screw using a hex 5.5 screwdriver.
    • Extra hands are helpful because this component will easily fall apart.
  14. Chef’s Counter Rice Cooker RC-3 Disassembly: 14 단계, 이미지 2개 중 1개 Chef’s Counter Rice Cooker RC-3 Disassembly: 14 단계, 이미지 2개 중 2개
    • Inspect the outer control panel, mechanical lever, and the components of the stack.
  15. Chef’s Counter Rice Cooker RC-3 Disassembly: 15 단계, 이미지 1개 중 1개
    • Now that the device is disassembled you can get a better understanding on how it works.
    • The rice cooker receives constant power when plugged in. A mechanical lever is used to switch between warm and cook settings. The settings are indicated by white LED lights with orange and red plastic coverings on the outer control panel.
    • A DF184S Thermal Cutoff Fuse is in place to protect the device by disconnecting the circuit in the event of a heating element malfunction.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 22
전체 시간: 205
