주요 콘텐츠로 건너뛰기
Chef's Choice M115 Linkage Pins Replacement
필요한 것
  1. Chef's Choice M115 Linkage Pins Replacement, Case: 1 단계, 이미지 1/2 Chef's Choice M115 Linkage Pins Replacement, Case: 1 단계, 이미지 2/2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Linkage Pins Replacement: 2 단계, 이미지 1/1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Linkage Pins Replacement: 3 단계, 이미지 1/1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Linkage Pins Replacement: 4 단계, 이미지 1/1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Linkage Pins Replacement, Grinding Disc Linkage Pins: 5 단계, 이미지 1/1
    • Remove the motor and shaft assembly from the bottom of the case housing.
  6. Chef's Choice M115 Linkage Pins Replacement: 6 단계, 이미지 1/2 Chef's Choice M115 Linkage Pins Replacement: 6 단계, 이미지 2/2
    • Use a screwdriver to push the pin out of the rod.
    • Use pliers to pull the pin the rest of the way out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Herin
회원 가입일: 10/27/15
128 평판
안내서 1개 작성함
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G3
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
Where would you obtain new linkage pins. Can I use a similar gauged wire? What, and where can I find a suitable replacement?
Josh Brown - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 1,748
