주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chef's Choice M115 Power Cord Replacement
필요한 것
    1. Chef's Choice M115 Power Cord Replacement, Case: 1 단계, 이미지 2개 중 1개 Chef's Choice M115 Power Cord Replacement, Case: 1 단계, 이미지 2개 중 2개
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      댓글 쓰기
    2. Chef's Choice M115 Power Cord Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      댓글 쓰기
    3. Chef's Choice M115 Power Cord Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      댓글 쓰기
    4. Chef's Choice M115 Power Cord Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      댓글 쓰기
    1. Chef's Choice M115 Power Cord Replacement, Power Cord: 5 단계, 이미지 2개 중 1개 Chef's Choice M115 Power Cord Replacement, Power Cord: 5 단계, 이미지 2개 중 2개
      • Carefully lift the entire motor assembly out of the case.
      댓글 쓰기
    2. Chef's Choice M115 Power Cord Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
      • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
      댓글 쓰기
    3. Chef's Choice M115 Power Cord Replacement: 7 단계, 이미지 1개 중 1개
      • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zachary Grounds
회원 가입일: 09/17/15
592 평판
안내서 3개를 작성함
팀
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G3
5 회원들
안내서 72개를 작성함
1가이드 댓글
I cannot find a replacement cord with the molded part that passes through the case. Is this something common (from hardware store), or do I need to find a part from the manufacturer?
Luke Shingledecker - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 91
전체 시간: 1,071
