소개
If the temperature of the air fryer isn’t changing after several adjustment, you’ve come to the right place. This guide will work you through how to replace your air fryer’s temperature potentiometer in a less confusing way and you do not need any special tools.
필요한 것
Please be sure that the device is unplugged and remove the frying basket from the device.
Orient your device where the both the timer knob and temperature knob are facing you.
Slide the plastic opening tool under the temperature knob to lift it up.
You can slide your fingers in between the gap and take the temperature knob off.
다른 한 분이 해당 안내서를 완성하였습니다.
