주요 콘텐츠로 건너뛰기
Chevy 305 Engine Connecting Rod Bearing Replacement
필요한 것
  1. Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: 1 단계, 이미지 2개 중 1개 Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: 1 단계, 이미지 2개 중 2개
    • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner
    • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Connecting Rod Bearing Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 5/8 nuts on the connecting rod end cap using the 5/8 socket
    • Gently tap the side of the cap with a rubber mallet if needed to break free.
  3. Chevy 305 Engine Connecting Rod Bearing Replacement: 3 단계, 이미지 1개 중 1개
    • Remove and replace connecting rod bearing
    • Gently tap the end cap against the engine block or use a thin flathead screwdriver to remove it from the end cap.
    • Gently move the piston and rod down into the cylinder to replace the rod end bearing.
    • DO NOT PUSH THE PISTON OUT OF THE CYLINDER.
  4. Chevy 305 Engine Connecting Rod Bearing Replacement: 4 단계, 이미지 1개 중 1개
    • Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
결론
To reassemble your device, follow these instructions in reverse order. Torque the connecting rod cap nuts to 65ft.-lbs. Torque the oil pan bolts to 12ft.-lbs.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joey Barton
회원 가입일: 10/30/19
397 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 75
전체 시간: 3,316
