주요 콘텐츠로 건너뛰기
Chevy 305 Engine Oil Pump Replacement
필요한 것
  1. Chevy 305 Engine Oil Pump Replacement, Oil pump: 1 단계, 이미지 2개 중 1개 Chevy 305 Engine Oil Pump Replacement, Oil pump: 1 단계, 이미지 2개 중 2개
    • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner
    • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Oil Pump Replacement: 2 단계, 이미지 2개 중 1개 Chevy 305 Engine Oil Pump Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the single 9/16 bolt holding the oil pump in place.
    • Using a rubber mallet to break loose, gently tap on the side of the base of the pump indicated by the arrow. DO NOT HIT THE TOP OF THE PICK UP TUBE AND SCREEN. This can potentially damage the pick up tube or screen.
  3. Chevy 305 Engine Oil Pump Replacement: 3 단계, 이미지 1개 중 1개
    • Pull straight up from the base of the oil pump to remove.
    • Replace with a new oil pump.
결론
To reassemble your device, follow these instructions in reverse order. Torque oil pump bolt to 60-70ft.-lbs. Torque oil pan bolts to 12ft.-lbs.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joey Barton
회원 가입일: 10/30/19
397 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 42
전체 시간: 4,081
