주요 콘텐츠로 건너뛰기
Children’s Soundbook Speaker Replacement
필요한 것
  1. Children’s Soundbook Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 1개 Children’s Soundbook Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 2개 Children’s Soundbook Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 3개
    • Remove the Phillips screw that secures the battery compartment cover.
    • Use a spudger to remove the batteries.
  2. Children’s Soundbook Speaker Replacement: 2 단계, 이미지 3개 중 1개 Children’s Soundbook Speaker Replacement: 2 단계, 이미지 3개 중 2개 Children’s Soundbook Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Gently remove the plastic speaker cover with a spudger.
  3. Children’s Soundbook Speaker Replacement: 3 단계, 이미지 3개 중 1개 Children’s Soundbook Speaker Replacement: 3 단계, 이미지 3개 중 2개 Children’s Soundbook Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the seven Phillips screws at the back of the speaker cover.
    • Use a pry tool to open the speaker cover.
  4. Children’s Soundbook Speaker Replacement: 4 단계, 이미지 3개 중 1개 Children’s Soundbook Speaker Replacement: 4 단계, 이미지 3개 중 2개 Children’s Soundbook Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the Phillips screws that secure the mainboard.
    • Your soundbook screws may use different head types.
    • Use tweezers to remove the orange magnetic cover and gently lift out the mainboard. Take care not to strain the connected wires.
  5. Children’s Soundbook Speaker Replacement: 5 단계, 이미지 2개 중 1개 Children’s Soundbook Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Desolder the two speaker mainboard connections (two yellow wires) with a desoldering pump.
    • To allow easier suction of the metal, heat them for a few seconds using a soldering iron first at 350°C. Always solder in a well-ventilated area or with a running fume extractor.
  6. Children’s Soundbook Speaker Replacement: 6 단계, 이미지 3개 중 1개 Children’s Soundbook Speaker Replacement: 6 단계, 이미지 3개 중 2개 Children’s Soundbook Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Using a soldering iron, solder the yellow wires of the new speaker to the mainboard.
    • Make sure that the soldering iron is set to 350°C.
  7. Children’s Soundbook Speaker Replacement: 7 단계, 이미지 3개 중 1개 Children’s Soundbook Speaker Replacement: 7 단계, 이미지 3개 중 2개 Children’s Soundbook Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • The remainder of guide details reassembly.
    • Put the inner casing back in its place, followed by the mainboard.
    • Refasten the Phillips screws.
    • Replace the cover and fasten the Phillips screws that secure it.
  8. Children’s Soundbook Speaker Replacement: 8 단계, 이미지 3개 중 1개 Children’s Soundbook Speaker Replacement: 8 단계, 이미지 3개 중 2개 Children’s Soundbook Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Replace the batteries and battery cover.
    • Fasten single Phillips screw that secures the battery cover.
    • Turn on the sound using the power button found in front of the sound case.
    • Try pressing the sound case buttons to check if sounds can be heard.
  9. Children’s Soundbook Speaker Replacement: 9 단계, 이미지 2개 중 1개 Children’s Soundbook Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Using a hot glue gun to reattach the sound case to the book and press it for a few seconds.
결론
Now your little one can play with their soundbook again!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Micaella Jimenez
회원 가입일: 02/06/25
187 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 153
