주요 콘텐츠로 건너뛰기
Choosing the Right Screwdriver Bit
필요한 것
  1. Choosing the Right Screwdriver Bit, Identification: 1 단계, 이미지 1/2 Choosing the Right Screwdriver Bit, Identification: 1 단계, 이미지 2/2
    • The screw bits in our iFixit bit kits have engraved prefixes that indicate the head type. These prefixes are typically followed by a number that indicates bit size. For example:
    • PH2 - (Phillips #2) A large Phillips bit.
    • PH0 - (Phillips #0) A medium Phillips bit.
    • PH000 - (Phillips #000) A small Phillips bit.
    • Choose the bit size that fills the screw head entirely. A bit that is too big or too small will not seat properly, and you'll end up with a stripped screw.
  2. Choosing the Right Screwdriver Bit: 2 단계, 이미지 1/2 Choosing the Right Screwdriver Bit: 2 단계, 이미지 2/2
    • If you find yourself scratching your head over identifying the bits in your tool kit, feel free to use this reference list.
    • Physical bit shape followed by proper name.
    • Bit size.
    • If there is no prefix engraved in your bit, simply use the full proper name and size when using your bit in a guide. (For example: "Use a 1.5 mm Flathead bit to remove the two 5 mm case screws.")
  3. Choosing the Right Screwdriver Bit, PH vs JIS: 3 단계, 이미지 1/2 Choosing the Right Screwdriver Bit, PH vs JIS: 3 단계, 이미지 2/2
    • Bits with the prefix "J" and "PH" are often thought to be the same bit. Don't be fooled by their similar appearance—they are quite different.
    • Phillips (PH) screws are designed to make a Phillips screwdriver cam out if too much torque is applied. This prevents damage to screws and screwdrivers or bits.
    • Japanese Industrial Standard (J) screws do not provide a cam-out option, and have 90 degree corners.
    • J (JIS) and PH (Phillips) driver bits are not always interchangeable. As you can see, they do not share identical physical properties.
결승점
다른 128명이 해당 안내서를 완성하였습니다.
Richard Suovanen
회원 가입일: 02/07/17
27,525 평판
안내서 11개 작성하였습니다
iFixit iFixit 회원
Community
138 회원들
안내서 17,042개 작성하였습니다
12 댓글
Excellent guide. could not figure out the difference by looking.
Lawrence Steinheuer-Turner - 답글
It would be clearer if the displayed drawing of each bit actually said J-bit or PH-bit, and because both have 90 degree corners, maybe change the J-bit description to “have 90 degree square inside corners“ and include in the PH description “have 90 degree rounded inside corners.
Otherwise, with interpretation, your article helped me.
Phil - 답글
what size hex shaft do these smaller bits have?. i have an electric precision screw driver, for electronics. i go through the PH1 bits very quickly. i can NOT find them for sale anywhere on earth. does anybody know where to purchase these things?? and/or tell me how i should word the query. all im getting is 1/4 hex shaft results. very frustrating
brett everett - 답글
In the picture on the top of the page the bits with a 90° corner are marked as Phillips heads, the ones with the rounded corners are markes as JIS heads. But it seems to be the other way, as mentioned in Step 3 of this instruction, and also according to other pages like Phillips #000 Screwdriver
Andreas Brunner - 답글
Sharp eye, Andreas! Thanks for catching that. We’ve updated the image at the top of the guide with the correct labels.
Marty Rippens -
댓글 쓰기
조회 통계:
24 시간 전: 218
7일 전: 1,471
30일 전: 7,246
전체 시간: 169,440
