주요 콘텐츠로 건너뛰기
소개
Choosing the wrong screwdriver bit can sometimes mean the difference between repair success and repair distress. Follow the tips in this guide to correctly identify your screwdriver bits and prevent those woeful stripped screws.
If you're still running into trouble with your screws after reviewing the information here, check out this awesome guide for some screwdriver tips.
  1. The screw bits in our iFixit bit kits have engraved prefixes that indicate the head type. These prefixes are typically followed by a number that indicates bit size. For example: PH2 - (Phillips #2) A large Phillips bit.
    • The screw bits in our iFixit bit kits have engraved prefixes that indicate the head type. These prefixes are typically followed by a number that indicates bit size. For example:
    • PH2 - (Phillips #2) A large Phillips bit.
    • PH0 - (Phillips #0) A medium Phillips bit.
    • PH000 - (Phillips #000) A small Phillips bit.
    • Choose the bit size that fills the screw head entirely. A bit that is too big or too small will not seat properly, and you'll end up with a stripped screw.
  2. If you find yourself scratching your head over identifying the bits in your tool kit, feel free to use this reference list. Physical bit shape followed by proper name.
    • If you find yourself scratching your head over identifying the bits in your tool kit, feel free to use this reference list.
    • Physical bit shape followed by proper name.
    • Bit size.
    • If there is no prefix engraved in your bit, simply use the full proper name and size when using your bit in a guide. (For example: "Use a 1.5 mm Flathead bit to remove the two 5 mm case screws.")
  3. Bits with the prefix "J" and "PH" are often thought to be the same bit. Don't be fooled by their similar appearance—they are quite different. Phillips (PH) screws are designed to make a Phillips screwdriver cam out if too much torque is applied. This prevents damage to screws and screwdrivers or bits.
    • Bits with the prefix "J" and "PH" are often thought to be the same bit. Don't be fooled by their similar appearance—they are quite different.
    • Phillips (PH) screws are designed to make a Phillips screwdriver cam out if too much torque is applied. This prevents damage to screws and screwdrivers or bits.
    • Japanese Industrial Standard (J) screws do not provide a cam-out option, and have 90 degree corners.
    • J (JIS) and PH (Phillips) driver bits are not always interchangeable. As you can see, they do not share identical physical properties.
    which is which? why not tag each with a label?
    Jay Heldman - 답글
    Oscar -
    Does a PH bit also fit into a J screw?
    Alberto - 답글
    Hiya, Alberto! Great question. Smaller screws found in electronics aren’t particularly durable, and using a Phillips screwdriver on a Japanese Industrial Standard screw head (or vice versa) can lead to some pretty major problems. I highly recommend using the proper screwdriver or bit to avoid stripping screws.
    Richard Suovanen -
    Which one should I get in America for iPhone and laptop type repairs , PH or J?
    eliyahu Stein - 답글
    According to JIS and ISO standard, both recess dimension seem to be the same, having a rounded corner between two flats. I think, the recess without rounded corners (as right drawing) is a recess of CIPA (older JCIS) standard. According to CIPA, the edge between two flats is R0.06mm rounded shape, which seems to be neary sharp edge. Anyway, CIPA is a Japanese Standard and used mainly for the screws of Japanese electrical instruments.
    gk3lglink - 답글
결승점
다른 99명이 해당 안내서를 완성하였습니다.
Richard Suovanen
회원 가입일: 2017년 02월 07일
22,037 평판
안내서 10개 작성하였습니다
Excellent guide. could not figure out the difference by looking.
Lawrence Steinheuer-Turner - 답글
It would be clearer if the displayed drawing of each bit actually said J-bit or PH-bit, and because both have 90 degree corners, maybe change the J-bit description to “have 90 degree square inside corners“ and include in the PH description “have 90 degree rounded inside corners.
Otherwise, with interpretation, your article helped me.
Phil - 답글
what size hex shaft do these smaller bits have?. i have an electric precision screw driver, for electronics. i go through the PH1 bits very quickly. i can NOT find them for sale anywhere on earth. does anybody know where to purchase these things?? and/or tell me how i should word the query. all im getting is 1/4 hex shaft results. very frustrating
brett everett - 답글
In the picture on the top of the page the bits with a 90° corner are marked as Phillips heads, the ones with the rounded corners are markes as JIS heads. But it seems to be the other way, as mentioned in Step 3 of this instruction, and also according to other pages like https://eustore.ifixit.com/products/phil...
Andreas Brunner - 답글
Sharp eye, Andreas! Thanks for catching that. We’ve updated the image at the top of the guide with the correct labels.
Marty Rippens -
i have just bought an ifixit kit, has some ph and j bits. I’ve looked at them under a microscope, compared angles, tried them on screws... i have found no difference whatsoever, they seem to be identical. What gives?
Victor Titov - 답글
Hi @deepsoic, that’s a pretty interesting find you’ve made! Send an email over to our customer service team at support@ifixit.com and they’ll help you get this issue sorted.
Amber Taus -
댓글 쓰기
조회 통계:
24 시간 전: 73
7일 전: 630
30일 전: 2,955
전체 시간: 78,687
