주요 콘텐츠로 건너뛰기
Chromebook 14-x015wm Keyboard Replacement
필요한 것
  1. Chromebook 14-x015wm Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Chromebook 14-x015wm Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Remove the small rubber circles over all four corners on the bottom of the chromebook.
    • Remove the three small additional rubber covers along edge of computer with hinge.
    • Unscrew all the screws on the bottom of the laptop using a Phillips #00 screwdriver.
    • Make sure to keep track of the screws for reassembly.
  2. Chromebook 14-x015wm Keyboard Replacement: 2 단계, 이미지 1/1
    • Flip the laptop back over to the front and open it so that the keyboard is visible.
    • Use the iFixit opening tool to pry off the keyboard by placing the tool in-between the keyboard and the case. Move the tool around all sides until the keyboard separates.
    • The keyboard will likely be difficult to remove.
    • Be careful to avoid pulling on the ribbons that connect the keyboard to the internal components in order to prevent damage.
  3. Chromebook 14-x015wm Keyboard Replacement: 3 단계, 이미지 1/1
    • Carefully unclip the ribbons under the keyboard to disconnect the keyboard.
    • Replace the keyboard and connect the ribbons to the new keyboard.
    • Press the computer case shut and replace the screws and rubber pads.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Michael Johnson
회원 가입일: 10/25/17
122 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G2, Isaacson Fall 2017 UMass Dartmouth, Team S1-G2, Isaacson Fall 2017 회원
UMASSD-ISAACSON-F17S1G2
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 433
