소개
This guide will show you how to replace the keyboard of the HP Chromebook 14-x015wm. After continual use, the keyboard may become unresponsive, if this is the case it is fairly easy to replace the keyboard rather than get a new computer. This guide outlines opening the case to get access to the components which connect the keyboard.
필요한 것
Remove the small rubber circles over all four corners on the bottom of the chromebook.
Remove the three small additional rubber covers along edge of computer with hinge.
Unscrew all the screws on the bottom of the laptop using a Phillips #00 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
