주요 콘텐츠로 건너뛰기
Chromebook 15 CB3-531-C4A5 Motherboard Replacement
필요한 것
  1. Chromebook 15 CB3-531-C4A5 Motherboard Replacement, Case: 1 단계, 이미지 2개 중 1개 Chromebook 15 CB3-531-C4A5 Motherboard Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Remove the 18 Phillips screws using a screwdriver with a PH0 bit.
  2. Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using a spudger, gently pry open the back from the top.
  3. Chromebook 15 CB3-531-C4A5 Motherboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Once it is opened up, locate the battery and the cable that is attached to it.
  4. Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Next, unscrew the battery pack. The one screw should be located on the far right of it. This will ensure that the battery comes out easily and affectively.
  5. Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Take the battery out easily for replacement.
  6. Chromebook 15 CB3-531-C4A5 Motherboard Replacement, Wireless Card: 6 단계, 이미지 1개 중 1개
    • Remove the two antenna cables that attach the wireless card to the motherboard. One will be black and the other will be white.
  7. Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the screw that holds the wireless card in place and then remove it using a screwdriver with a PH0 bit.
  8. Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the Wireless card out gently with two fingers while being careful not to damage any surrounding parts.
  9. Chromebook 15 CB3-531-C4A5 Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 Chromebook 15 CB3-531-C4A5 Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Remove the four Phillips screws.
  10. Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Remove tape that secures the ribbon cables.
    • Using the spudger, lift the latches to unlock each ribbon cable.
    • Remove the cables.
  11. Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the large black cable between the two ribbon cables.
  12. Chromebook 15 CB3-531-C4A5 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the remaining cable.
    • Remove the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Savannah Vining
회원 가입일: 01/17/17
940 평판
안내서 6개를 작성함
2가이드 댓글
RAM?
SSD?
Upgradable?
Removable?
www - 답글
How is this difficult lol, should be easy difficult fr
Alex Karpov - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 2,182
