주요 콘텐츠로 건너뛰기
Chromebook 15 CB3-531-C4A5 Wireless Card Replacement
필요한 것
  1. Chromebook 15 CB3-531-C4A5 Wireless Card Replacement, Case: 1 단계, 이미지 1/2 Chromebook 15 CB3-531-C4A5 Wireless Card Replacement, Case: 1 단계, 이미지 2/2
    • Remove the 18 Phillips screws using a screwdriver with a PH0 bit.
  2. Chromebook 15 CB3-531-C4A5 Wireless Card Replacement: 2 단계, 이미지 1/2 Chromebook 15 CB3-531-C4A5 Wireless Card Replacement: 2 단계, 이미지 2/2
    • Using a spudger, gently pry open the back from the top.
  3. Chromebook 15 CB3-531-C4A5 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 1/1
    • Remove the two antenna cables that attach the wireless card to the motherboard. One will be black and the other will be white.
  4. Chromebook 15 CB3-531-C4A5 Wireless Card Replacement: 4 단계, 이미지 1/2 Chromebook 15 CB3-531-C4A5 Wireless Card Replacement: 4 단계, 이미지 2/2
    • Locate the screw that holds the wireless card in place and then remove it using a screwdriver with a PH0 bit.
  5. Chromebook 15 CB3-531-C4A5 Wireless Card Replacement: 5 단계, 이미지 1/1
    • Slide the Wireless card out gently with two fingers while being careful not to damage any surrounding parts.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Savannah Vining
회원 가입일: 01/17/17
922 평판
안내서 6개 작성하였습니다
댓글 한 개
Thank You Soooo much. i did drop my laptop and i use it to pray w people via video call, so i was stressed some. i read all kinds of trouble shooting. but yours was so easy to read and do. the pictures helped me so much. took me a total of 10 minutes. the wifi card came out but was so simple to fix. thanks so much. im smiling big. God bless you. you saved the day for many people.
dianegonzales49 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 9
전체 시간: 829
