소개
You may need to replace the wireless card if it is faulty or does not display wireless settings. It will require taking the back of the computer off and replace the wireless card internally. There are no hazards accompanied with this task as long as the Chromebook is not charging.
필요한 것
Remove the two antenna cables that attach the wireless card to the motherboard. One will be black and the other will be white.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank You Soooo much. i did drop my laptop and i use it to pray w people via video call, so i was stressed some. i read all kinds of trouble shooting. but yours was so easy to read and do. the pictures helped me so much. took me a total of 10 minutes. the wifi card came out but was so simple to fix. thanks so much. im smiling big. God bless you. you saved the day for many people.
