주요 콘텐츠로 건너뛰기
Chromebook Pixel (2013) Battery Replacement
필요한 것
  1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: 1 단계, 이미지 2개 중 1개 Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: 1 단계, 이미지 2개 중 2개
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 2 단계, 이미지 3개 중 1개 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 2 단계, 이미지 3개 중 2개 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 2 단계, 이미지 3개 중 3개
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Chromebook Pixel (2013) Battery Replacement, Pop it open: 3 단계, 이미지 2개 중 1개 Chromebook Pixel (2013) Battery Replacement, Pop it open: 3 단계, 이미지 2개 중 2개
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): 4 단계, 이미지 2개 중 1개 Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): 4 단계, 이미지 2개 중 2개
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
  5. Chromebook Pixel (2013) Battery Replacement, Remove the bottom cover: 5 단계, 이미지 1개 중 1개
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  6. Chromebook Pixel (2013) Battery Replacement, Release the battery: 6 단계, 이미지 1개 중 1개
    • Remove the screws holding the battery in place.
  7. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: 7 단계, 이미지 2개 중 1개 Chromebook Pixel (2013) Battery Replacement, Unplug the battery: 7 단계, 이미지 2개 중 2개
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  8. Chromebook Pixel (2013) Battery Replacement, Examine the new battery: 8 단계, 이미지 1개 중 1개
    • Make sure that the wattage and voltage matches the values of the old battery
  9. Chromebook Pixel (2013) Battery Replacement, Install the new battery: 9 단계, 이미지 2개 중 1개 Chromebook Pixel (2013) Battery Replacement, Install the new battery: 9 단계, 이미지 2개 중 2개
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kevin Fessler
회원 가입일: 04/16/16
1,830 평판
안내서 4개를 작성함
2가이드 댓글
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - 답글
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 36
전체 시간: 7,774
