주요 콘텐츠로 건너뛰기
Chromebook x360 14-da0011dx Motherboard Replacement
필요한 것
  1. Chromebook x360 14-da0011dx Motherboard Replacement, Lower Case: 1 단계, 이미지 1/1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Motherboard Replacement: 2 단계, 이미지 1/2 Chromebook x360 14-da0011dx Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Motherboard Replacement: 3 단계, 이미지 1/3 Chromebook x360 14-da0011dx Motherboard Replacement: 3 단계, 이미지 2/3 Chromebook x360 14-da0011dx Motherboard Replacement: 3 단계, 이미지 3/3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Motherboard Replacement, Battery: 4 단계, 이미지 1/2 Chromebook x360 14-da0011dx Motherboard Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Motherboard Replacement: 5 단계, 이미지 1/2 Chromebook x360 14-da0011dx Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Motherboard Replacement: 6 단계, 이미지 1/1
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Motherboard Replacement, Fan: 7 단계, 이미지 1/1
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Motherboard Replacement: 8 단계, 이미지 1/2 Chromebook x360 14-da0011dx Motherboard Replacement: 8 단계, 이미지 2/2
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
  9. Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 9 단계, 이미지 1/3 Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 9 단계, 이미지 2/3 Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 9 단계, 이미지 3/3
    • Lift the ZIF connector locking flaps, then remove the ribbon cables.
    • There are several small connections for the ribbon cables. Exercise extreme caution when disconnecting the cables.
    • One ribbon cable is on the underside of the motherboard and will be removed later.
  10. Chromebook x360 14-da0011dx Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the three 3.0 mm Phillips #1 screws holding the motherboard in place.
  11. Chromebook x360 14-da0011dx Motherboard Replacement: 11 단계, 이미지 1/3 Chromebook x360 14-da0011dx Motherboard Replacement: 11 단계, 이미지 2/3 Chromebook x360 14-da0011dx Motherboard Replacement: 11 단계, 이미지 3/3
    • Disconnect the cables attached to the Wi-Fi card and motherboard along the top edge.
    • The leftmost connector is a ribbon-style connector with a metal locking bar that must be unlatched.
  12. Chromebook x360 14-da0011dx Motherboard Replacement: 12 단계, 이미지 1/3 Chromebook x360 14-da0011dx Motherboard Replacement: 12 단계, 이미지 2/3 Chromebook x360 14-da0011dx Motherboard Replacement: 12 단계, 이미지 3/3
    • Use a spudger to remove the tape and plastic shielding that secure the wires.
  13. Chromebook x360 14-da0011dx Motherboard Replacement: 13 단계, 이미지 1/1
    • Gently lift the motherboard until it is loose.
    • Disconnect the ribbon cable attached to the underside of the motherboard.
    • The locking flap on this ribbon cable must be flipped down to unlock.
  14. Chromebook x360 14-da0011dx Motherboard Replacement: 14 단계, 이미지 1/1
    • Lift the motherboard from the device.
    • Removal of the heat pipes may be necessary for replacement if your new replacement motherboard doesn't have one installed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jake Williamson
회원 가입일: 02/14/23
559 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 33
전체 시간: 243
