주요 콘텐츠로 건너뛰기
Chromebook x360 14-da0011dx Wireless Card Replacement
필요한 것
  1. Chromebook x360 14-da0011dx Wireless Card Replacement, Lower Case: 1 단계, 이미지 1/1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Wireless Card Replacement: 2 단계, 이미지 1/2 Chromebook x360 14-da0011dx Wireless Card Replacement: 2 단계, 이미지 2/2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Wireless Card Replacement: 3 단계, 이미지 1/3 Chromebook x360 14-da0011dx Wireless Card Replacement: 3 단계, 이미지 2/3 Chromebook x360 14-da0011dx Wireless Card Replacement: 3 단계, 이미지 3/3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Wireless Card Replacement, Wireless card: 4 단계, 이미지 1/1
    • Remove the plastic protector from the top of the wires plugged into the wireless card.
  5. Chromebook x360 14-da0011dx Wireless Card Replacement: 5 단계, 이미지 1/1
    • Remove the single 3 mm screw holding down the wireless card with the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Wireless Card Replacement: 6 단계, 이미지 1/2 Chromebook x360 14-da0011dx Wireless Card Replacement: 6 단계, 이미지 2/2
    • Disconnect the antenna cables leading into the wireless card.
    • Slide the wireless card out of its port and lift it out of the device.
    • The cables are numbered with their corresponding port. Be careful not to damage the connections when reassembling during this step.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jake Williamson
회원 가입일: 02/14/23
559 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 26
전체 시간: 147
