주요 콘텐츠로 건너뛰기
Chromecast Metal Shielding Replacement
필요한 것
  1. Chromecast Metal Shielding Replacement, Case: 1 단계, 이미지 1/1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Metal Shielding Replacement: 2 단계, 이미지 1/1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Metal Shielding Replacement: 3 단계, 이미지 1/1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Metal Shielding Replacement: 4 단계, 이미지 1/1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Metal Shielding Replacement: 5 단계, 이미지 1/2 Chromecast Metal Shielding Replacement: 5 단계, 이미지 2/2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Chromecast Metal Shielding Replacement, Metal Shielding: 6 단계, 이미지 1/1
    • Pry the metal extensions from the HDMI port.
  7. Chromecast Metal Shielding Replacement: 7 단계, 이미지 1/1
    • Insert the plastic opening tool into the corner next to the metal extensions, prying upward.
  8. Chromecast Metal Shielding Replacement: 8 단계, 이미지 1/1
    • Pry the metal piece around the metal, extruding it from the internal components.
  9. Chromecast Metal Shielding Replacement: 9 단계, 이미지 1/1
    • Completely remove the top metal casing to expose the internal components.
  10. Chromecast Metal Shielding Replacement: 10 단계, 이미지 1/1
    • Pry metal extensions from the HDMI port on the posterior side of the device.
  11. Chromecast Metal Shielding Replacement: 11 단계, 이미지 1/1
    • Insert the plastic opening tool under the corner to pry off the metal casing from the internal components.
  12. Chromecast Metal Shielding Replacement: 12 단계, 이미지 1/1
    • Continue prying around the device, removing the metal piece from the internal components.
  13. Chromecast Metal Shielding Replacement: 13 단계, 이미지 1/1
    • Completely remove the bottom metal piece.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Cameron Heiges
회원 가입일: 03/21/18
680 평판
안내서 3개 작성하였습니다
IUPUI, Team S5-G6, Baechle Spring 2018 IUPUI, Team S5-G6, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,622
