주요 콘텐츠로 건너뛰기
Chromo Inc. T2 Battery Replacement
필요한 것
  1. Chromo Inc. T2 Battery Replacement, Removing the Casing: 1 단계, 이미지 1/3 Chromo Inc. T2 Battery Replacement, Removing the Casing: 1 단계, 이미지 2/3 Chromo Inc. T2 Battery Replacement, Removing the Casing: 1 단계, 이미지 3/3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Battery Replacement, Turn it around: 2 단계, 이미지 1/1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Battery Replacement, Freeing the Battery: 3 단계, 이미지 1/3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: 3 단계, 이미지 2/3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: 3 단계, 이미지 3/3
    • Using the Spudger, going between the battery and screen, pry the battery off from the tablet.
    • Note: This will require a little extra force due to the tape holding down the battery!
  4. Chromo Inc. T2 Battery Replacement, Desoldering the Battery Wires: 4 단계, 이미지 1/1
    • Using a Soldering Iron, desolder both Battery wires.
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  5. Chromo Inc. T2 Battery Replacement, Finished!: 5 단계, 이미지 1/1
    • Your battery is now ready to be replaced!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ismael DeLuna
회원 가입일: 01/21/15
637 평판
안내서 5개 작성하였습니다
USF Tampa, Team 15-1, Watkins Winter 2015 USF Tampa, Team 15-1, Watkins Winter 2015 회원
USFT-WATKINS-W15S15G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 1,586
