주요 콘텐츠로 건너뛰기
Chromo Inc. T2 Touch Screen Replacement
필요한 것
  1. Chromo Inc. T2 Touch Screen Replacement, Touch Screen: 1 단계, 이미지 1/3 Chromo Inc. T2 Touch Screen Replacement, Touch Screen: 1 단계, 이미지 2/3 Chromo Inc. T2 Touch Screen Replacement, Touch Screen: 1 단계, 이미지 3/3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Touch Screen Replacement: 2 단계, 이미지 1/1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Touch Screen Replacement: 3 단계, 이미지 1/2 Chromo Inc. T2 Touch Screen Replacement: 3 단계, 이미지 2/2
    • Peel back the tape holding the big flex cable in place.
    • Using your plastic opening tool, gently push back the gray connector to free the flex cables and then pull them out.
  4. Chromo Inc. T2 Touch Screen Replacement: 4 단계, 이미지 1/2 Chromo Inc. T2 Touch Screen Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
    • Using a pair of tweezers, gently grasp the flex cable and disconnect it from the connector.
  5. Chromo Inc. T2 Touch Screen Replacement: 5 단계, 이미지 1/2 Chromo Inc. T2 Touch Screen Replacement: 5 단계, 이미지 2/2
    • Using a pair of tweezers, gently grasp the flex cable and pull it out while using your other hand to keep the camera in place. Once removed, your camera is now free to set aside.
  6. Chromo Inc. T2 Touch Screen Replacement: 6 단계, 이미지 1/2 Chromo Inc. T2 Touch Screen Replacement: 6 단계, 이미지 2/2
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws holding the motherboard.
  7. Chromo Inc. T2 Touch Screen Replacement: 7 단계, 이미지 1/3 Chromo Inc. T2 Touch Screen Replacement: 7 단계, 이미지 2/3 Chromo Inc. T2 Touch Screen Replacement: 7 단계, 이미지 3/3
    • Using your soldering iron, desolder the six wires on the side of the motherboard.
    • Note: Remember where these wires go as re-connecting them incorrectly can lead to damaging the device!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  8. Chromo Inc. T2 Touch Screen Replacement: 8 단계, 이미지 1/2 Chromo Inc. T2 Touch Screen Replacement: 8 단계, 이미지 2/2
    • Using your soldering Iron, desolder the grounding cable on the motherboard.
  9. Chromo Inc. T2 Touch Screen Replacement: 9 단계, 이미지 1/1
    • You can now remove your motherboard and set it aside.
  10. Chromo Inc. T2 Touch Screen Replacement: 10 단계, 이미지 1/3 Chromo Inc. T2 Touch Screen Replacement: 10 단계, 이미지 2/3 Chromo Inc. T2 Touch Screen Replacement: 10 단계, 이미지 3/3
    • Using your Plastic Opening Tool, pry between the plastic casing and the screen to free it. Once free, you may begin separating the screen from the casing.
  11. Chromo Inc. T2 Touch Screen Replacement: 11 단계, 이미지 1/3 Chromo Inc. T2 Touch Screen Replacement: 11 단계, 이미지 2/3 Chromo Inc. T2 Touch Screen Replacement: 11 단계, 이미지 3/3
    • Once removed from the plastic casing your touch screen is now free and ready for replacement!
결론
Ismael DeLuna
회원 가입일: 01/21/15
637 평판
안내서 5개 작성하였습니다
USF Tampa, Team 15-1, Watkins Winter 2015 USF Tampa, Team 15-1, Watkins Winter 2015 회원
USFT-WATKINS-W15S15G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,042
