주요 콘텐츠로 건너뛰기
Chumby One Motherboard Replacement
필요한 것
  1. Chumby One Motherboard Replacement, Chassis: 1 단계, 이미지 1/1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the back and bottom cover.
  4. Chumby One Motherboard Replacement: 4 단계, 이미지 1/1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Motherboard Replacement: 5 단계, 이미지 1/1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the inner components from the outer shell.
  10. Chumby One Motherboard Replacement, Motherboard: 10 단계, 이미지 1/1
    • Remove the speaker connector using a plastic spudger.
  11. Chumby One Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the Chumby button connector using a plastic spudger.
  12. Chumby One Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove three 6mm screws using a PH000 bit.
  13. Chumby One Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the motherboard by pulling straight away from the housing.
    • Removing the motherboard there are 2 pins and socket connectors that may cause injury.
결론
Jordan Houchins
회원 가입일: 03/27/17
401 평판
안내서 4개 작성하였습니다
IUPUI, Team S3-G3, Baechle Spring 2017 IUPUI, Team S3-G3, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S3G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 279
