주요 콘텐츠로 건너뛰기
Chumby One Speaker Replacement
필요한 것
  1. Chumby One Speaker Replacement, Chassis: 1 단계, 이미지 1/1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the back and bottom cover.
  4. Chumby One Speaker Replacement: 4 단계, 이미지 1/1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Speaker Replacement: 5 단계, 이미지 1/1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Speaker Replacement: 9 단계, 이미지 1/1
    • Remove the inner components from the outer shell.
  10. Chumby One Speaker Replacement, Speaker: 10 단계, 이미지 1/1
    • Remove the speaker wire connector from the motherboard.
  11. Chumby One Speaker Replacement: 11 단계, 이미지 1/2 Chumby One Speaker Replacement: 11 단계, 이미지 2/2
    • Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit.
  12. Chumby One Speaker Replacement: 12 단계, 이미지 1/1
    • Remove the speaker.
결론
Jordan Houchins
회원 가입일: 03/27/17
401 평판
안내서 4개 작성하였습니다
IUPUI, Team S3-G3, Baechle Spring 2017 IUPUI, Team S3-G3, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S3G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 167
