소개
Use this guide to repair your Cingular 8125 (HTC Wizard 110) Speakers that have static or no audio.
The cause of faulty or no audio is because the motherboard has some loose components. In this guide, you will be opening up the device and putting the components back into place.
You will be opening up the Cingular 8125 so it is highly recommended to open it up on a flat and clean surface. Placing a towel on a flat surface can work as well.
Step 4 will require you to touch the circuit board and move around parts so it is recommended that you keep your hands dry and clean to avoid getting debris into the device.
It can be a hazard to leave the power on while working on any circuit board so make sure you power off the device before starting.
Tools
- iFixit Opening Tool
- 64 Bit Driver Kit
필요한 것
Hold the phone with the back (camera side) facing you.
Press on the battery cover until it slides off.
