소개
This is a replacement guide for the Cirago M9030 Cover. The following steps will guide you in the dismantling and rebuilding of the cover as well as a replacement.
필요한 것
Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
거의 끝나갑니다!
In order to reassemble your device, follow these instructions in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
