주요 콘텐츠로 건너뛰기
Circline Fluorescent Light Bulb Replacement
필요한 것
  1. Circline Fluorescent Light Bulb Replacement, Circline Fluorescent Light Bulb: 1 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement, Circline Fluorescent Light Bulb: 1 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement, Circline Fluorescent Light Bulb: 1 단계, 이미지 3개 중 3개
    • Ensure the light is turned off. Approaching the fixture with the light on runs the risk of electric shock or eye irritation from the brightness.
    • Set up a stable step ladder under the light fixture. This replacement will require you to reach the ceiling of your room, so make sure that you will not fall when reaching up high.
    • Carefully climb the step ladder and remain close to your light.
  2. Circline Fluorescent Light Bulb Replacement: 2 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 2 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the light cover from the fixture.
    • The exact means of doing this may vary depending on your specific fixture.
    • For this specific cover, it needs to be twisted counter-clockwise to be taken down.
    • The exposed light fixture should look something like this.
  3. Circline Fluorescent Light Bulb Replacement: 3 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 3 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully remove the bulb from the metal supports. Some gentle force may be necessary.
    • Be careful not to break the bulb at any point during this guide as toxic mercury vapors are present within.
    • Hold the bulb steady with one hand so that its weight does not strain on the wire.
  4. Circline Fluorescent Light Bulb Replacement: 4 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 4 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 4 단계, 이미지 3개 중 3개
    • Firmly grab the connector and pull it out of the bulb socket.
  5. Circline Fluorescent Light Bulb Replacement: 5 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 5 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 5 단계, 이미지 3개 중 3개
    • Obtain a replacement bulb with identical wattage and diameter as your old bulb.
  6. Circline Fluorescent Light Bulb Replacement: 6 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 6 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 6 단계, 이미지 3개 중 3개
    • Hold the new bulb's socket near the hanging wire.
    • Insert the wire in same orientation as the old bulb was connected.
  7. Circline Fluorescent Light Bulb Replacement: 7 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 7 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 7 단계, 이미지 3개 중 3개
    • Place the new bulb into the metal supports. This may take some force applied to the metal supports to pull them back far enough for the bulb to be inserted.
  8. Circline Fluorescent Light Bulb Replacement: 8 단계, 이미지 2개 중 1개 Circline Fluorescent Light Bulb Replacement: 8 단계, 이미지 2개 중 2개
    • Flick your light switch on and see the results!
    • If it does not turn on, you may want to confirm the wired connection by unplugging and re-plugging it again.
  9. Circline Fluorescent Light Bulb Replacement: 9 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 9 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 9 단계, 이미지 3개 중 3개
    • Securely reattach your fixture's light cover.
  10. Circline Fluorescent Light Bulb Replacement: 10 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 10 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 10 단계, 이미지 3개 중 3개
    • Enjoy your new light!
  11. Circline Fluorescent Light Bulb Replacement: 11 단계, 이미지 3개 중 1개 Circline Fluorescent Light Bulb Replacement: 11 단계, 이미지 3개 중 2개 Circline Fluorescent Light Bulb Replacement: 11 단계, 이미지 3개 중 3개
    • Make sure you hold on to the old bulb and do NOT throw it in the trash.
    • Place the old bulb in a separate bin or bag, you can use this to start an e-waste collection to properly dispose of multiple electronic items.
    • Locate a recycling center that accepts e-waste and properly dispose of your old light bulb and any other e-waste you've collected.
결승점
작성자
3다른 기여자 명과 함께
Said Gonzalez Lopez
회원 가입일: 10/10/24
193 평판
안내서 1개를 작성함
UC Davis, Team 1-7, Morris Fall 2024 UC Davis, Team 1-7, Morris Fall 2024 회원
UCD-MORRIS-F24S1G7
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 43
지난 30일: 275
전체 시간: 1,745
