주요 콘텐츠로 건너뛰기
Circuit Board Housing Removal
필요한 것
  1. Circuit Board Housing Removal, Battery: 1 단계, 이미지 1/2 Circuit Board Housing Removal, Battery: 1 단계, 이미지 2/2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board Housing Removal: 2 단계, 이미지 1/2 Circuit Board Housing Removal: 2 단계, 이미지 2/2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board Housing Removal, Circuit Board Housing: 3 단계, 이미지 1/3 Circuit Board Housing Removal, Circuit Board Housing: 3 단계, 이미지 2/3 Circuit Board Housing Removal, Circuit Board Housing: 3 단계, 이미지 3/3
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board Housing Removal: 4 단계, 이미지 1/2 Circuit Board Housing Removal: 4 단계, 이미지 2/2
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board Housing Removal: 5 단계, 이미지 1/2 Circuit Board Housing Removal: 5 단계, 이미지 2/2
    • Remove the back cover completely from the phone.
결론
Jonathan Flowers
회원 가입일: 10/18/13
607 평판
안내서 6개 작성하였습니다
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013 회원
CLEM-BENSON-F13S14G7
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 600
