이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the horizontal grip located on the back cover of the phone.
Slide the back cover down and off of the phone.
Insert a plastic opening tool into the battery release point located above the battery.
Pull outwards in order to release the battery.
이 단계에 사용된 도구:Tweezers$4.99-
Locate the 5 screws holding the body of the phone together.
Using a Philips head screwdriver, twist counterclockwise to remove the screws.
Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
