소개
Whether your circular saw blade is worn out, or you just want to switch it out for a different style, it’s really easy to swap out blades on pretty much any circular saw—and it takes just a few minutes.
This guide uses a Ryobi P504G circular saw, but the process is very similar for most circular saws.
필요한 것
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Hello!
I learned a lot of important things, but I have a Question that is this Circular Saw perfect to cut Concrete Pavers?
I think you need a cutting disc in your circular saw
to cut concrete.
