주요 콘텐츠로 건너뛰기
Cisco Catalyst 2960-S Series Network Switch Fan Replacement
  1. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Prepare Tools: 1 단계, 이미지 1개 중 1개
    • You will need:
    • Phillips bit (PH2 size)
    • Flathead bit (size 6)
    • Socket bit (Size 1/4)
    • Multi-bit Screwdriver
  2. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove Brackets and Bolts from Left and Right sides of chassis: 2 단계, 이미지 2개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove Brackets and Bolts from Left and Right sides of chassis: 2 단계, 이미지 2개 중 2개
    • Using the Phillips bit, remove both brackets (if present) and the bolts installed on the left and right sides of the switch.
  3. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove Stack Module or Blank Cover: 3 단계, 이미지 3개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove Stack Module or Blank Cover: 3 단계, 이미지 3개 중 2개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove Stack Module or Blank Cover: 3 단계, 이미지 3개 중 3개
    • Your switch will have either a stacking module or blank cover at the back.
    • Loosen the two thumbscrews (using your screwdriver with the Phillips bit to assist if they are tight)
    • Using both loose screws, gently but firmly pull the module out of its slot.
  4. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove the Five remaining Chassis Screws at the rear: 4 단계, 이미지 2개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove the Five remaining Chassis Screws at the rear: 4 단계, 이미지 2개 중 2개
    • Using the flathead bit, remove the five chassis screws.
    • There are two at both ends, one next to the DC power socket, and two between the stack slot and fan exhaust.
  5. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Slide Cover back and lift away from the Chassis: 5 단계, 이미지 2개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Slide Cover back and lift away from the Chassis: 5 단계, 이미지 2개 중 2개
    • With all screws removed, the top cover should be free to slide to the rear, and can then be lifted away from the rest of the chassis, exposing the internal hardware of the switch.
  6. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Inspect fan and note nearby power supply cables: 6 단계, 이미지 2개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Inspect fan and note nearby power supply cables: 6 단계, 이미지 2개 중 2개
    • The fan assembly connects to the motherboard using a cable with four wires.
    • Familiarize yourself with the cables surrounding the fan assembly. These should not be moved around excessively in the next steps, nor should they be tampered with.
    • Note the two nuts securing the fan assembly to the chassis from above.
  7. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Unscrew nuts and remove Fan Assembly: 7 단계, 이미지 3개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Unscrew nuts and remove Fan Assembly: 7 단계, 이미지 3개 중 2개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Unscrew nuts and remove Fan Assembly: 7 단계, 이미지 3개 중 3개
    • Using the 1/4 socket bit, remove the two nuts securing the fan assembly.
    • Take care to prevent the nut closest to the Power Supply from being knocked near the internals of the Power Supply.
  8. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove the Fan Cable: 8 단계, 이미지 3개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove the Fan Cable: 8 단계, 이미지 3개 중 2개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove the Fan Cable: 8 단계, 이미지 3개 중 3개
    • The slack on the Fan cable may be tucked behind a cable tie.
    • Remove each wire individually to free the cable.
    • Remove the connector at the end of the from its header on the board.
  9. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Remove the Fan Assembly: 9 단계, 이미지 1개 중 1개
    • Lift the side of the Fan Assembly on the left (facing the rear of the switch), then slightly raise the right side, and lift up and away from the Power Supply.
  10. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Insert Replacement Fan: 10 단계, 이미지 1개 중 1개
    • Position the new Fan so that the right side (closes to the Power Supply) is angled down towards the bottom of the chassis.
    • Slide it under the Power Supply cable so that the cable sits on top of the edge of the Fan Assembly.
    • Lower in the rest of the Fan, and line the holes up with the bolts on the chassis, and lay the fan onto the bolts so that they poke through and hold the fan in its appropriate position.
  11. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Secure the Fan to the chassis: 11 단계, 이미지 3개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Secure the Fan to the chassis: 11 단계, 이미지 3개 중 2개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Secure the Fan to the chassis: 11 단계, 이미지 3개 중 3개
    • Since the nuts may not be magnetic, start with the nut closest to the Power Supply. Position it on top of the bolt as closely to flat as possible, and use the socket bit to screw the nut in and only mildly tighten.
    • This might take a few attempts. The nut may bounce away. Remove the Fan Assembly to retrieve the nut and try again until you are able to get it secured.
    • Secure the other side of the fan using the other nut.
  12. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Connect the Fan Cable and Secure the Slack: 12 단계, 이미지 3개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Connect the Fan Cable and Secure the Slack: 12 단계, 이미지 3개 중 2개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Connect the Fan Cable and Secure the Slack: 12 단계, 이미지 3개 중 3개
    • Connect the connector in the same orientation as before.
    • Tuck the excess slack on the wires under the cable tie, being careful to allow enough slack to remain to prevent strain on the wires.
  13. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Cover: 13 단계, 이미지 2개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Cover: 13 단계, 이미지 2개 중 2개
    • Place cover onto the chassis (positioned slightly to the back, same as when it was removed)
    • Slide to the front to close the cover.
  14. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Rear Chassis Screws: 14 단계, 이미지 1개 중 1개
    • Using the Flathead bit, reinstall the five screws on the rear of the Chassis.
  15. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Stack Module or Cover: 15 단계, 이미지 3개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Stack Module or Cover: 15 단계, 이미지 3개 중 2개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Stack Module or Cover: 15 단계, 이미지 3개 중 3개
    • Insert the Module into its slot in the same orientation that it originally was.
    • Do not use a screwdriver. Hand tighten the screws to secure the Module or Cover into place.
  16. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Screws and Brackets on both sides: 16 단계, 이미지 3개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Screws and Brackets on both sides: 16 단계, 이미지 3개 중 2개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Install Screws and Brackets on both sides: 16 단계, 이미지 3개 중 3개
    • Use Phillips bit to fasten the remaining Chassis screws in, and install the brackets on both sides of the Switch.
  17. Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Recommended: Verify Fan Health and System Temperature: 17 단계, 이미지 3개 중 1개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Recommended: Verify Fan Health and System Temperature: 17 단계, 이미지 3개 중 2개 Cisco Catalyst 2960-S Series Network Switch Fan Replacement, Recommended: Verify Fan Health and System Temperature: 17 단계, 이미지 3개 중 3개
    • Power on the Switch. Connect your console cable and launch your serial terminal. (If you use SSH to access your switch, log in once it is finished booting).
    • Elevate, and run the following commands:
    • sh env fan
    • sh env temp
    • Both should show OK.
결론
작성자
1다른 기여자 명과 함께
G B
회원 가입일: 05/25/23
310 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 27
지난 30일: 67
전체 시간: 1,719
