주요 콘텐츠로 건너뛰기
Cisco Meraki MC74-HW Phone Sensor Replacement
필요한 것
  1. Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: 1 단계, 이미지 3개 중 1개 Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: 1 단계, 이미지 3개 중 2개 Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: 1 단계, 이미지 3개 중 3개
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Phone Sensor Replacement: 2 단계, 이미지 2개 중 1개 Cisco Meraki MC74-HW Phone Sensor Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Phone Sensor Replacement: 3 단계, 이미지 3개 중 1개 Cisco Meraki MC74-HW Phone Sensor Replacement: 3 단계, 이미지 3개 중 2개 Cisco Meraki MC74-HW Phone Sensor Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Phone Sensor Replacement: 4 단계, 이미지 2개 중 1개 Cisco Meraki MC74-HW Phone Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW Phone Sensor Replacement, Phone Sensor: 5 단계, 이미지 2개 중 1개 Cisco Meraki MC74-HW Phone Sensor Replacement, Phone Sensor: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Disconnect the ribbon from the phone sensor board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW Phone Sensor Replacement: 6 단계, 이미지 3개 중 1개 Cisco Meraki MC74-HW Phone Sensor Replacement: 6 단계, 이미지 3개 중 2개 Cisco Meraki MC74-HW Phone Sensor Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two 1.2 mm screws holding the phone sensor using a Phillips #0 screwdriver.
    • Carefully lift the phone sensor to remove it from the device.
결론
작성자
4다른 기여자 명과 함께
Anthony Kairouz
회원 가입일: 10/18/21
253 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-5, Simcock Fall 2021 UMass Dartmouth, Team 1-5, Simcock Fall 2021 회원
UMASSD-SIMCOCK-F21S1G5
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 250
