주요 콘텐츠로 건너뛰기
Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement
필요한 것
  1. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, Back Housing and Device Stand: 1 단계, 이미지 1/3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, Back Housing and Device Stand: 1 단계, 이미지 2/3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, Back Housing and Device Stand: 1 단계, 이미지 3/3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 2 단계, 이미지 1/2 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 2 단계, 이미지 2/2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 3 단계, 이미지 1/3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 3 단계, 이미지 2/3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 3 단계, 이미지 3/3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 4 단계, 이미지 1/2 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 4 단계, 이미지 2/2
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, USB and Headphone Jack Inputs Board: 5 단계, 이미지 1/2 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, USB and Headphone Jack Inputs Board: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the ribbon cable on the board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 6 단계, 이미지 1/3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 6 단계, 이미지 2/3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 6 단계, 이미지 3/3
    • Remove the three 2 mm screws holding the USB and headphone jack inputs board using a JIS #00 screwdriver.
    • Carefully lift the board until you have clear access to the electronic connector.
  7. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 7 단계, 이미지 1/2 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: 7 단계, 이미지 2/2
    • Disconnect the electronic connector on the board using a pair of reverse tweezers.
    • Carefully lift the board to remove it from the device.
결론
Jeremy Chdid
회원 가입일: 10/18/21
198 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-5, Simcock Fall 2021 UMass Dartmouth, Team 1-5, Simcock Fall 2021 회원
UMASSD-SIMCOCK-F21S1G5
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 138
