주요 콘텐츠로 건너뛰기
Clarinet Cork Replacement
필요한 것
  1. Clarinet Cork Replacement, Cork: 1 단계, 이미지 1/1
    • Using pliers, remove the old cork by pinching it off.
  2. Clarinet Cork Replacement: 2 단계, 이미지 1/1
    • Clean the joint with soap and water
  3. Clarinet Cork Replacement: 3 단계, 이미지 1/1
    • Measure the width of the tenon joint.
    • Only measure the area where the cork will lie, not the entire joint.
  4. Clarinet Cork Replacement: 4 단계, 이미지 1/1
    • Cut the new cork to match the width of the tenon joint.
  5. Clarinet Cork Replacement: 5 단계, 이미지 1/1
    • Peel off the backside of the cork to reveal the adhesive.
  6. Clarinet Cork Replacement: 6 단계, 이미지 1/1
    • Wrap the cork around the joint.
  7. Clarinet Cork Replacement: 7 단계, 이미지 1/1
    • Sand the cork with sandpaper until the cork is smooth.
  8. Clarinet Cork Replacement: 8 단계, 이미지 1/1
    • Apply cork grease on the new cork.
  9. Clarinet Cork Replacement: 9 단계, 이미지 1/1
    • Slowly twist and slide the joint back together.
결론
Once your clarinet is reassembled, leave the joint together for at least a few hours to let the cork compress and adhere properly. Play the fully assembled clarinet or blow some air through the joint to check for any leaks. When you are ready to put it away, disassemble it carefully. Enjoy your new cork!
다른 7명이 해당 안내서를 완성하였습니다.
Hill Xiong
회원 가입일: 10/26/17
257 평판
안내서 1개 작성함
UC Santa Barbara, Team S3-G1, Weedon Fall 2017 UC Santa Barbara, Team S3-G1, Weedon Fall 2017 회원
UCSB-WEEDON-F17S3G1
3 회원들
안내서 1개 작성하였습니다
댓글 3개
Where do you buy the corks from? Could you post a link to them?
Joshua Leung - 답글
Make sure to use sandpaper with around 60 - 80 grit
[deleted] - 답글
Wat if the cork strips don't have adhesive.wat do I use
kendall mckenzie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 30
30일 전: 141
전체 시간: 13,194
