소개
This guide shows how to remove and replace the handle and handle tube on the Clarke Floor Buffer 01278A.
You can use regular hand tools for removing fasteners, but using an impact driver will make the procedure easier.
필요한 것
Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
Pull the wires connected to the interlock assembly straight out of their connectors.
Use a 3/16" hex key or driver bit to remove the 13.8 mm-long screw securing the power cord's green ground wire to the handle enclosure.
Make sure the handle tube is secured in place by checking that the cam lock is in the locked position.
Brace the back of the floor buffer with your foot near the wheel axle and grasp the handle with both hands.
Slowly tilt the floor buffer back until the handle rests on your work surface.
Use a 3/16" hex key or driver bit to remove the four 18.6 mm-long screws securing the shield brush to the bottom of the floor buffer.
Remove the three 12.6 mm-long Phillips #2 screws securing the bottom cover to the floor buffer.
Untwist and remove the yellow wire nuts from the black, brown, and red wires.
Remove the two 12.4 mm-long Phillips #2 screws securing the strain relief plate to the floor buffer.
Loosen the cam lock and tilt the handle all the way back until it rests on your work surface.
다른 4명이 해당 안내서를 완성하였습니다.
